586,974 active members*
2,953 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Fidia
IndustryArena Forum: Fidia
Page 1 of 2 12
Threads 1 to 20 of 27
Discuss Fidia machine controllers here.
    02-05-2023, 06:36 PM Go to last post
  1. Fidia F1
    Started by viorel23cnc, 12-07-2019 09:30 AM
    change, english, fidia, german, menu
    02-06-2022, 07:42 PM Go to last post
  2. FIDIA controller, GANTRY MACHINE
    Started by danby, 11-25-2021 05:03 PM
    aligned, axis, gantry, loop, machine
    11-25-2021, 05:03 PM Go to last post
  3. Loosing PLC program on FIDIA F1.0190
    Started by giahinader, 05-17-2020 09:35 AM
    08-04-2021, 07:46 AM Go to last post
    02-20-2021, 10:26 PM Go to last post
    01-22-2021, 11:12 AM Go to last post
  4. Enable serial rs232 connection to external pc
    Started by viorel23cnc, 05-01-2020 03:45 PM
    connection, controller, dnc, pins, serial
    05-01-2020, 03:45 PM Go to last post
  5. Question Fidia M20.f g-code help
    Started by Tomax, 02-09-2017 06:32 AM
    07-29-2019, 04:49 AM Go to last post
  6. Fidia C20 problems
    Started by OsKirill, 04-23-2016 06:09 AM
    04-23-2016, 06:09 AM Go to last post
  7. [Fidia M1] syntax register use
    Started by chilli-nc, 03-24-2012 04:00 PM
    03-28-2012, 03:09 PM Go to last post
  8. Fidia, tool change point
    Started by Mecof3, 03-12-2012 04:54 PM
    03-16-2012, 12:04 PM Go to last post
  9. appraoching problem
    Started by Mr_Mill, 02-13-2012 08:31 AM
    02-14-2012, 01:49 PM Go to last post
  10. 3D zero contour
    Started by rapido, 01-24-2012 09:36 PM
    01-26-2012, 04:13 PM Go to last post
  11. error message
    Started by ANI-MAT, 11-25-2011 10:09 AM
    11-25-2011, 03:55 PM Go to last post
  12. wireless hand wheel for FIDIA controller
    Started by Fisch, 12-07-2010 03:42 PM
    11-01-2011, 04:00 PM Go to last post
  13. subprogram Fidia
    Started by Erneston, 10-19-2011 06:15 AM
    10-19-2011, 06:15 AM Go to last post
  14. switch off MECOF via FIDIA
    Started by mecof73, 08-30-2011 07:58 AM
    09-14-2011, 05:15 PM Go to last post
  15. Level transportation & CQA
    Started by Magmahon, 03-05-2010 07:42 PM
    04-12-2011, 04:10 PM Go to last post
  16. Cutter compensation G41 via Laser
    Started by mlewan_ca, 03-07-2011 09:46 PM
    03-07-2011, 09:46 PM Go to last post
  17. FIDIA display
    Started by mecof73, 01-26-2011 05:50 PM
    01-26-2011, 05:50 PM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
