586,974 active members*
4,307 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Diemaking / Diecutting
IndustryArena Forum: Diemaking / Diecutting
Page 1 of 7 123
Threads 1 to 20 of 140
Discuss Diemaking and Diecutting here.
  1. cutting edge for 3mm Mild steel sheet
    Started by fsa, 08-28-2023 07:15 AM
    08-28-2023, 07:15 AM Go to last post
  2. Tips for making simple steel rule dies
    Started by leathersmith, 02-07-2007 07:57 PM
    2 Pages
    1 2
    dies, doi, rule, simple, steel, step
    03-06-2023, 04:29 AM Go to last post
    12-13-2022, 03:24 PM Go to last post
  3. How to polish drawing dies after milling?
    Started by Jim27, 11-30-2022 04:45 AM
    12-01-2022, 09:13 PM Go to last post
  4. HDPE for drawing aluminum sheet?
    Started by Jim27, 06-27-2022 03:57 AM
    aluminum, drawing, hdpe, planning, thick
    11-21-2022, 07:42 PM Go to last post
  5. Shaped sheet metal punch
    Started by Jim27, 01-09-2018 01:31 PM
    2 Pages
    1 2
    06-22-2022, 06:04 PM Go to last post
  6. Die tool used on Lapel pins???
    Started by cyberdine, 01-29-2007 09:20 AM
    01-18-2021, 05:48 AM Go to last post
    09-30-2020, 07:14 AM Go to last post
    07-23-2020, 10:49 AM Go to last post
  7. inserts to machine harden material
    Started by cob, 03-25-2020 06:05 AM
    i.d, inserts, material, open, recommend
    03-25-2020, 07:32 PM Go to last post
  8. Removing feed-thru punch from wood die board?
    Started by iWAYNE, 05-06-2019 08:07 PM
    05-07-2019, 11:02 PM Go to last post
  9. Tripping Breaker on New Clicker Press
    Started by iWAYNE, 07-29-2018 03:57 PM
    3 Pages
    1 2 3
    07-31-2018, 09:08 PM Go to last post
    04-09-2018, 03:31 PM Go to last post
  10. toughest steel
    Started by cob, 04-03-2018 05:23 AM
    appreciated, steel, strong, thinking, toughest
    04-04-2018, 01:48 AM Go to last post
  11. Brass Tubing Into a Cone - Die Metal Type?
    Started by jesset, 02-25-2018 09:45 PM
    brass, forum, make, metal, tubing
    02-26-2018, 11:54 PM Go to last post
    02-25-2018, 10:28 PM Go to last post
  12. Machining accurate pockets and features
    Started by Jim27, 12-29-2017 04:45 AM
    cnc, cut, size, suggested, test
    12-31-2017, 04:40 PM Go to last post
  13. Making a radius punch and die
    Started by Jim27, 12-27-2016 05:18 AM
    3 Pages
    1 2 3
    12-24-2017, 04:43 AM Go to last post
  14. Dowel pins for punching small holes?
    Started by Jim27, 12-09-2017 04:19 PM
    dowel, holes, milling, pins, side
    12-21-2017, 02:17 AM Go to last post
  15. How is finish polishing on punch dies done?
    Started by Jim27, 11-23-2017 07:47 PM
    cnc, dies, finish, mill, smooth
    12-21-2017, 02:12 AM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
