586,974 active members*
3,187 visitors online*
Login Register
Vero Software - Banner
Vero Software Forum
Charter Oak Automation Support Forum
IndustryArena Forum: Charter Oak Automation Support Forum
Page 1 of 34 12311
Threads 1 to 20 of 670
Discuss Industrial Hobbies/Charter Oak Automation Milling machines and get direct support here.
    05-02-2024, 01:48 AM Go to last post
  1. Charter Oak mill x-axis backlash help
    Started by mattinaustin, 03-27-2023 07:15 PM
    03-29-2023, 09:30 PM Go to last post
  2. Main Motor for IH Mill ZAY7045FG ?
    Started by richlandrick, 02-06-2022 07:07 PM
    main, mill, motor, plate, unreadable
    02-08-2022, 10:11 PM Go to last post
  3. IH Controller schmaticm + specs
    Started by qbit, 04-15-2021 02:36 AM
    charter, cnc, control electronics, industrial hobbies mill, specs
    05-14-2021, 02:46 PM Go to last post
  4. ball screw nut replacement
    Started by bit pusher, 04-13-2021 04:11 AM
    ball, nut, replacement, screw, tommy
    04-23-2021, 03:48 PM Go to last post
    04-17-2021, 04:32 AM Go to last post
  5. IH ENCODERS
    Started by bohica, 12-31-2020 01:03 AM
    apparently, bit, cnc, dust, encoder
    12-31-2020, 01:03 AM Go to last post
  6. IH SERVO MOTOR
    Started by bohica, 12-10-2020 06:21 PM
    jim, motor, replacement, sell, servo
    12-10-2020, 08:54 PM Go to last post
  7. Sometimes the Z axis Drops after power-down
    Started by pryotex, 03-25-2017 09:28 AM
    drops, occurred, power, time, tool
    01-22-2020, 10:30 PM Go to last post
  8. Large seal in head under the motor, 35x62x...?
    Started by QSIMDO, 12-26-2019 10:45 PM
    35x62x12, head, motor, removed, seal
    12-26-2019, 10:45 PM Go to last post
  9. Head bolt dimensions head spacer
    Started by williamsmotower, 12-05-2019 05:53 PM
    bolt, column, dimensions, head, special
    12-05-2019, 05:53 PM Go to last post
  10. Glad I didnt Buy One !
    Started by madman, 09-15-2014 03:50 PM
    10-03-2019, 02:51 AM Go to last post
  11. How to Change Bearings - COA Square Col
    Started by Danal, 09-20-2019 10:58 PM
    bearings, load, running, spindle, square
    09-22-2019, 11:08 PM Go to last post
    08-11-2019, 10:25 AM Go to last post
  12. Charter Oak not responding?
    Started by QSIMDO, 08-01-2019 04:22 PM
    anymore, full, mail, mailbox, voice
    08-02-2019, 08:56 PM Go to last post
    07-10-2019, 04:05 AM Go to last post
  13. BT/NT30 Spindle for 12Z Mill?
    Started by tulsah, 01-18-2019 04:04 AM
    12z, assuming, bt/nt30, cnc, spindle
    05-16-2019, 02:27 PM Go to last post
  14. Model C8250
    Started by crazybrit, 04-23-2019 02:04 AM
    04-24-2019, 01:18 AM Go to last post
  15. Spindle Problem?
    Started by bohica, 03-07-2019 08:46 PM
    cnc, problem, rpm, running, spindle
    04-07-2019, 05:44 PM Go to last post
    03-10-2019, 01:02 PM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
